Which one? Z-28 axle or Exhaust? - FirebirdV6.com/CamaroV6.com Message Board
  • Which one? Z-28 axle or Exhaust?
    I'm debating which i should get: a Z-28 rear axle (LSD and 3.42s) or a cat-back exhaust. I know that the exhaust frees up horsepower, but the 3.42s will help get the available power to the wheels better. which should i go for?
    \'98 Camaro - SOLD<br />Best E/T: 15.489 @ 86.48 MPH<br />60\': 2.131<br /><a href=\"http://members.cardomain.com/skorpion317\" target=\"_blank\">members.cardomain.com/skorpion317 </a><br />1998 Saturn SL2<br />Official <a href=\"http://www.njdisturbance.com\" target=\"_blank\">NJ Disturbance</a> bracket racer
    rear end swap.
    Then spend $20 for a cut out and have a shop put it in untill you can afford full cat back exhaust.
      Rear end definately. In the long run you will thank yourself for getting the rear end. And you get disk brakes.
      There is fast, too fast, and way too fast. Way too fast is almost fast enough.
        He already has disc brakes.
          Go with the rear, the first time you go to the track you will understand why.
          My old car.<br />2000 Firedird 5-Speed<br />1/4 E.T. 15.601 @ 88.659 w/2.411 60\'<br /><br />New car.<br />1999 T/A 6-Speed<br />1/4 E.T. 13.181 @ 106.971 w/2.15 60\'
            go with rear end
              rear end it is then. time to look around my local junkyard for a Z-28...
                Not all Z-28s are 3.42...be careful.
                  i thought they all were? what other gears do they come with?
                    i think the auto have 3.23
                    www.turbov6camaro.com
                    1997 3800 Series II Camaro
                      I think the autos come with 2.73
                        why would an auto Z-28 come with 2.73s, when the auto v6's come with 3.08s? that doesn't make sense.
                          v8 has more torque to turn the 2.73
                          some V8 has 3.23 cuase there are ALOT of 3.23 out there in V8 rears
                            You can check the RPO codes on the cars you see so that you can check the gears.
                              2.73s are lower-performance than the 3.42s...torque has nothing to do with it.
