P0113- "Intake Air Temp Circuit High Input" this is what flashed when the diagnostic machine was plugged up. I assume this is the small sensor/wire that is attached to the intake. Well we took a look and it has been spliced! I don't know whether it was a small animal or sabotage. The car had been in storage since October. Anyway does anyone know where I can get one of those connectors? Is this even the problem?
Pulled trouble code at Autozone -- P0113
just reconnect the wires and get the code cleared.
BTW, its called the IAT sensor (Intake Air Temperature)<a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
what do you mean spliced?
"Splicing" a wire is when you shave the rubber off of two wires and connect them. "Splicing" is what you need to do.
Youre going to have to be more descriptive if you expect us to know what youre talking about ;)<a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
How more descriptive can I get? The wire is completely seperated from the connector. It may have been cut or chewed through. The wire left on the connector end is too short to sucessfully connect to the other end. Therefore I need a new connector. I need to know where I can get this connector and do I have to go the dealer to have the code cleared.
By "spliced" I meant cut or seperated but not reconnected.
Theyre around $20 at the dealer, let me see if I can find the part number for it.2002 5-spd NBM Camaro
Details: www.1lev6.com
just simply SPLICE the cut wire back together.. tada.. not brain sergery96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
<blockquote>quote:</font><hr>Originally posted by Tyler:
just simply SPLICE the cut wire back together.. tada.. not brain sergery<hr></blockquote>
Did you not read his post? It is too short to reconnect. You could always solder in the resistor and it'll be fine...don't rememebr the value of resistor you'll need, but it tricks your computer into thinking it's always cooler outside, and therefore advances your timing a bit...not a bad next to free mod for an NA car. and you'll save $19.95! Do a search and you'll find what resistor you need to do this.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
or you can just go to a junk yard?96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Sorry I read this late but you could have gottn it at just about any auto parts store(ie Pep Boys) for about 7 bucks. Its in the electrical wire section w/ the weather packs.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...12 hours ago
