hi, im curious, how the heck do i do it?
Paperclip trick on OBD1 computers
Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.Tags: None
1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
<blockquote>quote:</font><hr>Originally posted by 2.8 slow to go:
jump the pins before tuning the key to the "on" position. go to autozone & get free key<hr></blockquote>
I tried it that way too. I had to go see a mechanic to pull them.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
shadly, what did they use to pull your codes
because im getting a service engine soon and autozones obdII thingy cant find any codes people have been telling me i have an obdI, but thats BS cuz it has a obdII plugCamaro 95 3.4L M5<br />Flowmaster 80srs<br />Catco High Flo Cat<br />Slp CAI<br />Prime wheels
<blockquote>quote:</font><hr>Originally posted by Reg Kmet:
hi, im curious, how the heck do i do it?<hr></blockquote>
Your car should have the OBD2 style connector so you can't flash codes via the SES light......however, in case you're interested or need to do this on an older car, read this:
EDIT: pics didn't work, go here to see the whole post: http://www.thirdgen.org/techbb2/show...highlight=ALDL
(borrowed from TGO)
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area. There should be a small rectangular cover over the access hole in the lower dash trim.
Insert a tool as described above (paper clip) into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) and it will begin to flash. This is also commonly called the "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
[ April 11, 2002: Message edited by: Dan90RS ]</p>Dan<br />1990 RS 170,000 miles<br />3.4L collecting dust<br />700R4-to-T5 swap completed on Dec. 13, 2002
<blockquote>quote:</font><hr>Originally posted by michael:
because im getting a service engine soon and autozones obdII thingy cant find any codes people have been telling me i have an obdI, but thats BS cuz it has a obdII plug<hr></blockquote>
Honestly, I don't know what he used. I know it was new and I know it cost $10,000, but I don't know what it was called. It's supposed to pull codes from everything. Autozone probably won't be able to pull your codes. They're counter-monkeys, not technicians.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
just because you have an "OBDII" plug doesn't mean you have OBDII, it could be I...
I have no freaking clue why ppl keep calling it the OBDII plug since it is documented it was on OBDI cars, so how could it be something before it exsists? Hmmmmm....2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
<blockquote>quote:</font><hr>Originally posted by strobhen:
I have no freaking clue why ppl keep calling it the OBDII plug since it is documented it was on OBDI cars, so how could it be something before it exsists? Hmmmmm....<hr></blockquote>
The ODBII Standard was in research and development almost imediately after ODBI was introduced. People call the connector ODBII because it's the same 16 pin connector used on the newer computers (True ODBII)
In late 94, early 95, the ODBI computers were attached to a harnes that terminated with a 16 pin connector that is the same as the ODBII computers.
-BrianMaroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
I HAVE A 3RD GEN AND WHEN I JUMP MY TWO PINS THEY ARE THE ONES IN THE TOP RIGHT CORNER. BUT MAKE SURE THE CAR IS OFF AS YOU JUMP THE PIN. THEN TURN THE KEY TO ON. THE ENGINE LIGHT WILL BLINK CODES FOR THE PROBLEMS........86 PONT FIREBIRD (334 PROJECT)<br />87 PONT FIREBIRD 2.8 SLP STAINLESS EXHAUST, K+N OPEN AIR INDUCTION, 8MM WIRES, BOSCH PLATINUM PLUGS, HIGH VOLTAGE ALTERNATOR, CHIP, SOON TO HAVE PORTED PLENUM AND THROTTLE BODY, ADJUSTABLE FUEL REGULATOR. SHES A 2.8 BUT SHE RUNS.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
