everytime i make a right hand turn my car makes a weird noise, it happens when i am comin out of the turn and makin the wheel straight, it sounds like a knock, just happens once each time, i turn come out of it and KNOCK! its louder sometimes then others but im lost, what do u think it might be?
weird sound
Originally posted by asdf1234:
Possibly your CV Joint?
It sounds like you've got a worn ball joint on your car, or loose lugnuts on your wheel, or perhaps your strut bolts are loose, or your steering knuckles are loose from your a-arms.
Start with the ball joint on the steering knuckle and work from there.2001 Camaro, 3.8 v6. Five speed. Red. SLP Torque arm, SLP CAI, adj. panhard bar, lcas, eibach springs, 3.73 gears and Zexel-Torsen T-2 LSD.
Make sure you tranny mount bolts are all tight...mine had a similar problem and one of my tranny mount bolts wasn't tightened all the way down.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
I doubt this is it, but i had a knocking sound when i would turn or accelerate and it was right under the shifter. It turned out to be my two piece drive shaft. If thats what it is, replace it with a solid once piece, its cheaper, and quiter. I did that and the car is great now. But im not sure thats what it is...
Mine kinda makes this noise that you speak of but its when I turn right or hit bumps. Its my wheel or axle bearing I'm pretty sure.\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
