does the LS1 thermostat fit my 1999 3.8?
Thermostat
No - get this one.
http://www.slponline.com/view_produc...TNUMBER=1001602002 5-spd NBM Camaro
Details: www.1lev6.com
160 - you will have no problems with it. It does not wear out your radiator, your waterpump, or anything else. It simply opens up sooner to allow the engine to run cooler if its possible due to radiator size and ambient air temp.2002 5-spd NBM Camaro
Yeah, but if your PCM has a low engine temperature set point and your engine temperature goes below it and stays below it ....
Cooling fans are constantly on, you will lose the engine temperature and the inevitable SES light ... 2001 A4 firebird ... this has also happened to a 2001 A4 camero.
If anybody would like to commment, I am looking for suggestions.Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
