Whats the PROPER way to check the fuses in our cars? should i disconnect the negative terminal of the battery? and then just pull em out? thanks in advance.
checking fuses (need help)
Dont disconnect the battery. Just pull them out. Usually if the fuse is blown it will have a black discoloration near the tips.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
