has anyone ever removed the inside door panel, if so what are the steps involved, any help would be appreciated. The other day while my power window was going up, something i don't know what, a window guide or something popped out of the panel and now i can't lower or raise the window wihout it going off the track.
thanks burtcam, 94 camaro
Your vertical guide bearing busted. It's a common problem on F-bodies from what I have gathered. I had to fix mine, I just welded the seam and the bearing in place..works fine.. but I have to replace the motor now. As for taking off the panel, I drive a Firebird.. and it's a little different.
