I remember reading about it somewhere, there being a red wire that you can use to wire stuff up with. i don't really feel like running another wire under the door panel from the battery accesory pole. which, any, red wire can i splice into if i want to get power for a switch? thanks.
under dash red wire power tap????
Do you need +12V at all times or just when the ignition is on? For on all the time, use the red wire coming from behind the cig lighter. For on w/ignition, look at the bundle of wires (probably taped over) that goes from under the steering column towards the passenger side of the car. You can get to it pretty well from the area on the right side of the gas pedal that goes all the way over to the passenger side. Untape a small section of that wire bundle and pull out a pink wire. That will come on when you turn the key forward or back.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
<blockquote>quote:</font><hr>Originally posted by 96BeastV6:
Do you need +12V at all times or just when the ignition is on? For on all the time, use the red wire coming from behind the cig lighter. For on w/ignition, look at the bundle of wires (probably taped over) that goes from under the steering column towards the passenger side of the car. You can get to it pretty well from the area on the right side of the gas pedal that goes all the way over to the passenger side. Untape a small section of that wire bundle and pull out a pink wire. That will come on when you turn the key forward or back.<hr></blockquote>
cool didnt know that about the ignition....thx I can use that...
05' CTS-V
00' Camaro - SOLD :(
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...12 hours ago
