My Service Engine light keeps coming on. I went to Autozone they plugged in one of those Actron diagnostic computers to it and it picked up an error code 1133. The diagnostic reset the computer so the light went away for about 40 miles and then came on. Does anyone know what this code means? The tech from Autozone didn't have the code list for it.
okay so you didnt list a real email address, i have some more info on that error code, if you send me your real email addy ill send it to you, and just so you know, not disclosing your actual email address is enough to get kicked out of this place.
Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
<blockquote>quote:</font><hr>Originally posted by vtv6firebird: okay so you didnt list a real email address, i have some more info on that error code, if you send me your real email addy ill send it to you, and just so you know, not disclosing your actual email address is enough to get kicked out of this place.<hr></blockquote>
<blockquote>quote:</font><hr>Originally posted by Dekay: My email is dekay@attbi.com
I'm assuming I need a new O2 sensor? <hr></blockquote>
not necessarily. for instance, there could be a problem with the circuit for that sensor instead of the sensor itself. usually insufficient switching does indicate a bad sensor though.
but let me emphasize the importance of accurate and thorough diagnosis, rather than throwing a part at a problem. AZ scans codes for free because they know that when they tell you the description of the code they exponentially increase their chances of selling you the part that the code refers to; often however, the code is caused by a problem with the circuitry for that sensor or a related system, not the sensor itself. the pcm has no way of knowing what part of the circuit the fault is in, it just sees a value for a particular sensor that is out of the range that was programmed to be "acceptable."
Ok, so what should I do? Should I take it to a repair shop and let them figure it out?
<blockquote>quote:</font><hr>Originally posted by strange_trp:
but let me emphasize the importance of accurate and thorough diagnosis, rather than throwing a part at a problem. AZ scans codes for free because they know that when they tell you the description of the code they exponentially increase their chances of selling you the part that the code refers to; often however, the code is caused by a problem with the circuitry for that sensor or a related system, not the sensor itself. the pcm has no way of knowing what part of the circuit the fault is in, it just sees a value for a particular sensor that is out of the range that was programmed to be "acceptable."<hr></blockquote>
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
