Engine sounds different?? - FirebirdV6.com/CamaroV6.com Message Board
  • Engine sounds different??
    Hi. I just got my 99 3.8L Camaro a couple of months ago. When I first got it, whenever I'd start it, the "low oil" light would come on for about 1 minute each time. I was told by my friend, who knows cars a lot better than I do, that it was probably normal. I put 89 octane fuel in the engine all of the time.
    Now, a couple of weeks ago I started putting in 87 because there's no real reason to put in 89... I'm betting it's a coincidence, but around this time my engine starting sounding different. The low oil light no longer comes on when I start up the car, it doesn't sound as "clean." It sounds a little duller. I suppose that's the right term to use. There also sounds like there's a very slight buzzing noise coming from the engine in high RPMs.
    The car response seems to be a little bit slower, and it seems to be a little bit less smooth to shift. I guess that could all be in my head, but eh.
    Well, any ideas? Any help at all would be appreciated, I just got this car and I really want to avoid this becoming a problem in the future.
    No clue, but you shouldn't be getting a low oil light. Is the oil pressure not coming up quickly or is the oil sending unit going bad?
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      I'll check the pressure next time I thought the car (I'm an extreme newbie to this, forgive me)
      I bought it used, but I do know that I have NO idea what has been done to this car... I managed to get it up to 130, or at least above 120, in 4th gear, so apparently the governor is broken. I think our cars have governors. But regardless...
      Man, I probably have to get this entire thing looked at/tuned, don't I?
