Dyno results, Do they seem low? - FirebirdV6.com/CamaroV6.com Message Board
  • Dyno results, Do they seem low?
    http://dynoperformance.com/search_details.php?ID=480
    went and redynoed, the guy just went threw 1st and 2nd so what ur looking at is power as if I were drag racing and it had just shifted gears. I stock dynoed at 138.6hp @5200rpm and 165tq @3800rpm. mods listed on the sheet are only mods. Car is in pretty good working order other than my Throttle position sensor being slightly off.
    Edit: the car is auto, which is why it was dynoed that way-
    [ June 22, 2003: Message edited by: Takumi Fujiwara ]</p>
    97 Special Edition Bird , Short bus stlye special
    why would they do it in 1st and second gear???
    i thought it was supposed to be in 3rd gear for automatics?
    and 4th gear for 5speeds..
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
      Those are reallllly low.. even for a stock car..
      at most dyno's you can dyno in any gear.. but its better to do it i na higher gear so you get a more accurate/smoother graph..
      I dunno.. those graphs are really chopped off also.. next time try and get them to start the dyno at a lower RPM..
      BTW.. you kunkle head.. look at your peak #'s on the images not the fist number on the table.. you dynoed 155.4 hp / 200.3 TQ.. [img]graemlins/rofl.gif[/img]
      If these graphs are accruate then there is possably something wrong with your car.. you shuld be 150-160ish stock.. The mods you have are not that extensive though.. So i would not sweat it too much..
      just for the record though, THOSE GRAPHS ARE PIMP!! and they post it all on the web.. hella cool.. I wish all dyno shops were as decked out as that..
      but as far as the numbers go all i can say is, sorry man.. good luck figureing out whats up..
      ~Bill
      [ June 23, 2003: Message edited by: AllTheGoodNamesAreGone ]</p>
        Dyno was performed in 3rd dood =). But to get it up to speed he powered threw the gears. Yea, somethings up with the car. track times are 15.5 @90mph... with said mods. Im guessing that the Throttle position sensor is messing up my air fuel ratio... not sure how to fix that though.
          Did they do a wide band air fuel ratio?? I would be happy with the TQ numbers if the dyno is correct..
          Jeff ..
          1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
          2002 WS6 T/A.. Bolt ins..448rwhp
          2009 G8 GT.. Vararam intake, GXP axleback
          1998 Corvette.. Vararam intake, Ti axleback
          http://www.fquick.com/slow-v6
            <blockquote>quote:</font><hr>Originally posted by 1998silverbird:
            Did they do a wide band air fuel ratio?? I would be happy with the TQ numbers if the dyno is correct..<hr></blockquote>
            dude.. look at the second picture (the one on the right)
            ~Bill
              You're a/f ratio seems a little rich. You should be more around a 12.8-13.0, so you're losing a little power there.
              Don't worry about measuring how good your car is by the dyno numbers, use it more as a comparison between mods and as a tool to check a/f ratio. Some dynos read higher/lower then others.
              Chris
              <b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
                Max RWHP: 155.4 @ 5040 rpms
                Max RWTQ: 187.9 @ 3950 rpms
                Estimated Fly Wheel Horsepower: 199 @ 5040 rpms [assuming 22 % drivetrain loss]
                Estimated Fly Wheel Torque: 241 @ 3950 rpms [assuming 22 % drivetrain loss]
                Thats what it says on the website- the estimates look just about right for a stock engine.
                All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
                  when i was pretty much stock i dynoed 174 RWHP and 214 RWTQ with just a muffler everything else stock on a hot houston summer day...
                    <blockquote>quote:</font><hr>Originally posted by hawgs:
                    when i was pretty much stock i dynoed 174 RWHP and 214 RWTQ with just a muffler everything else stock on a hot houston summer day...<hr></blockquote>
                    175 225 here, same thing as you, with my A4 3.42 Firebird.
                    2002 5-spd NBM Camaro
                    Details: www.1lev6.com
                      yes mine was a 99 A4 3.42 as well... forgot to mention that.
                        See my point is, Its not to test mods, my mods have helped, thats no doubt, but my main problem is that my car is way under what It should be. I dont even want to keep the car anymore its bothering me so much. But thx for the numbers guys.
                          3.4 or 3.8? That makes a huge difference.
                            hawgs and dom-a-hoe are both 3.8's, and so am i for that matter.. 197/224
                              even with an auto i seriosuly doubt we lose 22% maybe 17-18% max with stock tranny
                              Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                                2 days ago
