electrical problem - FirebirdV6.com/CamaroV6.com Message Board
electrical problem
  • electrical problem
    as of right now, my left turn signal doesn't work, but the bulb is not burned out. The left, dim headlight is not working, but it has just been replaced, and only works sometime. Also, the speakers on the left side of the car don't work. Every now and then everything works fine. But most of the time all three things are "out of order". Where should i start? Thanks!
    <a href=\"http://www.cardomain.com/memberpage/618356\" target=\"_blank\">http://www.cardomain.com/memberpage/618356</a> <br /><br />1997 black camaro RS A4<br />5% tint on sides and back<br />K&N filter<br />Port and Polished heads <br />Pioneer 4100, 2-10\" rockford HE\'s w/ custom box, MTX Blue thunder 400x5<br />B&B Triflo w/ quad tips<br />Chrome RS emblems
    The only thing I can think of that links those things together is the fuse box. Have you had a collision on the left side of the vehicle.
    Note: Have you checked out the RedLineVSix forum in the Regional?? It's all Ohio guys.
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
      theres never been a collision, i've had the car for bout 2 years and these problems started about a month ago. i am hoping i can fix it myself before I have to fork out an arm and a leg to get something minor fixed. Thanks again!
