To those that have used it could you really tell if it helped you out? I have about 500mi left before my next oil change and thought of trying it and then going to a place that can flush engine oil to make sure it is all nice and clean.
Sea Foam
i think it helped quite a bit when i used it. only thing is...it's kinda scary to see all that white smoke coming out the tailpipes. nothing is broken, that's just all the muck that has been pulled off the engine being burned up. actually, i think it may be time for that again.you can\'t get off if you don\'t get on
You're local GM parts dealer should sell it too. It's AKA top engine cleaner. ;)Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
what exactly does seafoam do to the engine? i know its a type of cleaner. does it help extend the life of the engine if done reguarly?1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
To clean the throttle body and intake, remove the vacuum line that connects the MAP to the throttle body. Pour sea foam into the vacuum tube while the car is running, until the car dies (Or until about a 1/2 a cup or so has been poured in). Turn the car off, and wait about 5-10 minutes. Start the car and let it idle for quite a while. You'll know it's working because of the ungodly amount of white smoke dumping out of the exhaust. Don't worry. it's normal. Run until smoke is gone. Hope this helps. I did this on my car a while ago, and it seemed to really help.1997 Y87 Camaro with a motor and some stuff.
arent you supposed to pour the rest into the crank case and some into the gas tank ....thats what i read2001 SOM Camaro SS<p>Direct flo lid---Lakewood LCAs----Edelbrock Torque Arm-----Lous Short Stick---Dynomouth 3\" Exhaust---SLP Center Mount Exhaust---Poly tranny and torque arm mounts.<p>My site....http://community.webshots.com/album/49413018hRfdbP
