Sea Foam - FirebirdV6.com/CamaroV6.com Message Board
Sea Foam
  • Sea Foam
    To those that have used it could you really tell if it helped you out? I have about 500mi left before my next oil change and thought of trying it and then going to a place that can flush engine oil to make sure it is all nice and clean.
    1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
    i think it helped quite a bit when i used it. only thing is...it's kinda scary to see all that white smoke coming out the tailpipes. nothing is broken, that's just all the muck that has been pulled off the engine being burned up. actually, i think it may be time for that again.
    you can\'t get off if you don\'t get on
      where can i get sea foam? [img]graemlins/dunce.gif[/img]
      <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
        Napa. How many miles did you have on your car?
          You're local GM parts dealer should sell it too. It's AKA top engine cleaner. ;)
          Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
            when i did the seafoam stuff, i had around 80k on my car i think. somewhere close to that.
              what exactly does seafoam do to the engine? i know its a type of cleaner. does it help extend the life of the engine if done reguarly?
              1996 Camaro 3.8L A4<br />*RK Sport Headers, RT High Flow Cat, B&B Tri-Flo Catback w/Quad Tips<br />*17\" Camaro SS Rims w/Firestone Firehawk SZ50 EP (275/40/17 Front, 285/40/17 Rear)<br />*SLP Speedometer Recalibrator<br />*American Sports Car SS Style Hood, Painted Green Disc Calipers and Drum Shells<br />*Charcoal Leather Interior
                I heard some one using in the vacuum system, where they put it in at? By the brake booster, in the 1/2inchish looking rubber tube?
                  Yeah hopefully someone can also fill me and I'm sure others as well on what exactly seafoam does.
                  I have roughly 90k on my car and I'm sure theres junk in there that should be cleaned. So lets hear the Seafoam 101 Basics!
                    To clean the throttle body and intake, remove the vacuum line that connects the MAP to the throttle body. Pour sea foam into the vacuum tube while the car is running, until the car dies (Or until about a 1/2 a cup or so has been poured in). Turn the car off, and wait about 5-10 minutes. Start the car and let it idle for quite a while. You'll know it's working because of the ungodly amount of white smoke dumping out of the exhaust. Don't worry. it's normal. Run until smoke is gone. Hope this helps. I did this on my car a while ago, and it seemed to really help.
                    1997 Y87 Camaro with a motor and some stuff.
                      arent you supposed to pour the rest into the crank case and some into the gas tank ....thats what i read
                      2001 SOM Camaro SS<p>Direct flo lid---Lakewood LCAs----Edelbrock Torque Arm-----Lous Short Stick---Dynomouth 3\" Exhaust---SLP Center Mount Exhaust---Poly tranny and torque arm mounts.<p>My site....http://community.webshots.com/album/49413018hRfdbP
                        You can. I never did, though.
                          where can you get it besides napa?
