Suppose a person had a away to get AC-type cooled air into there intake (65* and below), what do you suppose would be the safest, coolest temp you could get without causing problems, ie things cracking and breaking? I figure it could handle into the low 30's because weather gets at least that cold. Would external temp be a factor? Would you need to keep engine coolant temps way down too? And before anyone says anything, yes I know the ac compressor strain would negate any cold air advantages. So whats ya think?
95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
