Update on Hypertech Power Programmer 3 for the V6 F-Body!!! See inside... - FirebirdV6.com/CamaroV6.com Message Board
  • Update on Hypertech Power Programmer 3 for the V6 F-Body!!! See inside...
    Let me tell you what I've been doing these last few days....
    Last Thursday, I took my car to Hypertech so they can use it to fine tune their Hypertech Power Programmer III for the 2000 model 3.8L V6 F-Body.
    Today, Matt (Amped96) and I went to Hypertech to check out the progress of their tuning on my car. They ran 3 stock programmed ECM dyno pulls and with the 3 runs logged, I averaged 184.7 RWHP and 212.4 RWTQ. See dyno sheet here... http://wtfba.hispeed.com/stuff/stock_dyno.jpg
    Then they put in their Hypertech chip into their opened ECM and pulled 2 more runs. I averaged 190.7 RWHP and 223.6 RWTQ. See the two dyno sheets here... http://wtfba.hispeed.com/stuff/power_dyno1.jpg and http://wtfba.hispeed.com/stuff/power_dyno2.jpg
    With the dyno program, they can pinpoint exact points on the chart. I was seeing gains up to 11 RWHP and 15 RWTQ throughout the range!!! The average gain was 6.0 RWHP and 11.2 RWTQ! Not too shabby! ;)
    The Power Tuning was set for 93 octane and I've been running 87. I had 1/2 tank of 87 octane in the tank and they put 93 in the tank and run it down a little. I figure by the time the car is flushed with 93 octane, it should gain another horsey or three! :D
    They're going to spend the next few days eliminating the knock retard between 1400 RPMs and 2300 RPMs, completing the 93 Octane Power Tuning, and then they're going to work on the 87 Octane Power Tuning. They're also having trouble finding the top speed limiter (location is different from the 2001 model) but should have it solved by Thursday.
    So far, everything seems to be going well. I'm looking forward to seeing some good gains from the HPP3 and the benefits of the Power Tuning, Fan temp control, speed limiter, and rev limiter. Overall time with the programmer should net higher gains after the programmed ECM gets used to the fuel trims and other sensors.
    I'll keep everyone up-to-date on the progress of the Hypertech Power Programmer 3! I plan to attend the Beech Bend Bash III (with the Programmer), October 27, to get some stock ECM track times and Power Tuned ECM times.
    Meanwhile.... they've supplied me with a 2001 Chevy Silverado 5300 Vortec (5.3L V8)! I've had a lot of fun driving it around, leaving dual rubber strips, and barking 2nd gear quite often! ;) :D
    Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
    Cool will it still work with a slighly or heavily modded car? About when will it be out the public and How Much $$$$$$$$$$$$$?
    Silver 2000 Firebird A4<br />3.8 A4<br />14.746 @91.98 Feb /03/02<p>1990 Mitsu GSX 5Spd I just got it.<p>Otis for President 04 !!!!!!
      Will we be able to use it to *only* eliminate the governor and adjust the speedo for gear changes? Or does it automatically adjust the timing as well? If I advance my timing my engine will blow... but I'm tired of my speedo being off...
        When they finish fine tuning their programmer, they're going to send out about 20 to 30 units for beta testing (like they did awhile back ago with 2001 models). If they get a good response back from their beta testers, then they will be released for major production. I'll be Beta tester #1! :D
        I don't know the cost of the programmer but I would assume they'd be nearly the same, if not the same, price as the LT1 & LS1 HPP3s!
          <BLOCKQUOTE>quote:</font><HR>Originally posted by Stefan:
          Will we be able to use it to *only* eliminate the governor and adjust the speedo for gear changes? Or does it automatically adjust the timing as well?<HR></BLOCKQUOTE>
          Hey Stefan! Good to hear from you again! :D
          From me actually seeing a HPP3 for the 97 LT1 cars, you have seperate options of Power Tuning, gear changes, tire changes, shift points, etc.... I haven't actually seen the HPP3 for our V6'ers yet. They have an opened ECM they put their flashed chip in for testing.... I'll confirm your question when the programmer is in my hands (hopefully Thursday or Friday).
            Ummm Anyone wants to buy a USED JET module?? :D :D :D
              What model years will this work on?
              -James<br /><br />\'96 3.8L A4 Camaro (SOLD)
                This particular one is for the 2000 models only.
                They've already released the 2001 beta testers. Lots of people here had negative comments about the 2001 beta test. :(
                http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=000907
                  Where are they located? I'd like to drop my 3.4L off with them if they'll work on a programmer for it.
                    Bartlett, TN (near Memphis) :D
                      <BLOCKQUOTE>quote:</font><HR>Originally posted by Jason McCallister:
                      This particular one is for the 2000 models only.<HR></BLOCKQUOTE>
                      Will the '96 never get a programmer? ;)
                        No kidding! ;)
                        Red 96' A4 Firebird
                        Audio Audio and Autotek
                        Check it out here!
                          I have a 2000 camaro.. So hopefully it works out.
                          <UL TYPE=SQUARE><LI>Xenon Hyperwhite Headlights and fog lights<LI>Reflective concepts inserts <LI>Whisper Lid with K&N filter<LI>B&B Tri-flo quad tip exhaust</UL><BR> <A HREF=\"http://community-2.webtv.net/aquahaven/2000ChevyCamaro/\" TARGET=_blank>http://community-2.webtv.net/aquahaven/2000ChevyCamaro/</A>
                            Can I get an email address for someone at hypertech? I'd like to look into this. TN is only 6 hours away from here.
                              Im hoping the '96 will get a programmer, but the way they worded it today is that everything back to 98 is a go for sure. We will have to wait and find out i guess.
                              I'm sure you can select which tuning you want or don't. I have a friend who has it on his '00 T/A with just shiftpoints slightly adjusted and none of the timing adjustments.
                              <b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
