i just but a air fuel ratio gauge but i dont know where to hook it up to the key start/12 volt and i am wireing the air fuel ratio to the o2 just before the cat so does anyone know what wire to splice into/color and where to hook up the 12 volt to the key start.
air fuel ratio gauge install
yes, check out the 'install car alarm section'. brent will show you how to access the back of the interior fuse panel. you may want some blue 'quick link' connectors as well. (IMHO a must have addition to auto wiring crimp fittings kit) there is a nice spot for a ground near the steering wheel shaft cross member. you will see the bolt when the lower dash covers are off and you look up into the dash. make sure battery is disconected while you remove the fuse panel. you can use a simple conductivity tester and test the back of the fuse panel leads when the fuse block is pulled out...key in run position. ( i almost have these pics up on my website...brents site is great though.)
http://www.bfranker.badz28.com/fbody/Guides.htm
Grayman, you mean solderless connectors? Oh trust me I got very used to those when I recently installed my CD player in my 74 Vette.
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
