On my crossmember in the middle of the car, the one u gotta take off to put on the exhaust piping....one of the bolts was broken off in the hole and none of it is sticking out so i can remove it, question is basically whats the best way to remove a broken off bolt, and i cant get a hold of it with pliers or of the sort. any suggestions? the result of the broken bolt tho is that my dash and suspension squeak now, and it didnt do it till after i got the exhaust put on, so i know its cause of that bolt.
broken off bolt
broken off bolt
Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force'sTags: None
Easy-outs. Basically a reverse-cut drill bit.
You could drill it with a regular bit but you risk damaging the threads.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Definitely an easy-out. They work wonders [img]smile.gif[/img] .-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Use an easy out, but is this the same crossmember behind the tranny mount, made of flimsy metal.
yo0u don't need it you could take it off or even hold it on with 3 bolts. heck mine had 3 bolts for 6-months after I lost one, but I found a spare in my box of spare nuts in bolts of camaros from previous years. On my 94 I think I ran awhile with it off.
Actually I guess you'd be better off using an easy out, its a good thing to practice on, if you mess up you really don't need that bolt, and it would be good practive for when you break a bolt on a head or something, and you actualy do need to get it out.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
easyout is your best bet but if there is anything at all sticking out you can usually get hold of it with a cold chisel and little taps with a hammer. hold chisel at almost a 90 degree angle to the bolt and tap it in the correct direction if it is not to tight it will usually back out.Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...2 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...4 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
