horn problems - FirebirdV6.com/CamaroV6.com Message Board
horn problems
  • horn problems
    when i press the horn buttons on my steering wheels not only does nothing happen, but the voltage and oil pressure drops until i let go. All the lights flash. what could be the problem? im not a master electrician, is it the fuse or it is the wiring?
      Alternator? Electrical short?
      [ January 04, 2005, 12:40 AM: Message edited by: 98Camaro3.8 ]
      Matt
      1998 Mystic Teal Camaro M5
        it might be a short, but once again i know nothing. how would i fix that? if it was the alternator why would everything else work?
          what if you hit a fire hydrant and physically broke your horn in the process, how u fix that
          99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
            That is a short....check the wires at the horn....or the horn relay may be bad. Either way, if it's loading down other electrical components, it's a short.
            Quick troubleshooting tip, unplug both horns, hit the button, and see what happens.
            If the power still dips, it's either the horn relay, one of the horn buttons, or wiring.
            Pull the relay, and hit the button again. If the problem is gone, it's the relay, if the problem is still there, it's the wiring or the horn button.
              great idea, thank you.
