I've actually had a good deal of experience, at least with the Jet chip.
The timing advance the chips lend can make a good different performance wise as long as you don't get any retard from the PCM.
I live in NY and my experience has always been that during the cold fall/winter months the chip would consistently push my car .2 faster in the 1/4 with 94 octane fuel.
Problem, for me, started in the Summer. I actually noticed at the AIS that my car was running like crap compared to its usual runs (15.5s and 15.6s). I ran about 8 times with the same consistent results, then I yanked the chip and instantly ran a 15.39 and a 15.33 (which was right for my car in those conditions).
My theory (I don't have an autotap so I can't back this up) is that the timing advance works wonders when there is ample amounts of icy cold air blasting into the engine and across the radiator, but in the Summer the timing advance causes slight knock and a PCM timing retard which can actually reduce preformance.
Of course, this applies really only to my car, but it *could* be one reason why some people seem to gain, some people lose, and some people see nothing.
You and I are thinking the same, Infernal. I wrote something real similar in a post last week. Do you use the 91 or 93 octane and low temp. stat. Pardon, I didn't check your sig.
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
