There is some debate about how often to change the fuel filter. Some say change it only when it is clogged. However, it is so simple to change that I change mine every third oil change or about every 10,000 miles.
Basically, the procedure is: 1. Relieve the fuel system pressure. 2. Raise the vehicle. 3. Clean all the fuel filter connections and the surrounding areas before disconnecting the fuel lines in order to avoid possible contaminator of the fuel system. 4. Disconnect the quick-connect fitting at the fuel filter inlet . 5. Disconnect the threaded fitting from the fuel filter outlet. 6. Slide the fuel filter from the bracket . 7. Inspect the fuel pipe O-ring (on the filter). Replace the O-ring if necessary.
After you have removed the fuel filter, installation is obvious.
If you are changing the filter yourself you will need a pan to catch the fuel that comes from the filter and line, some rags, the proper size open-end wrench, flare-nut wrench, O-ring and new filter. Obviously, be careful to not expose the fuel to any spark.
That's about it.
2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
it's not that complicated, and you can skip about the first million steps on this page. basically jack the car up, open gas cap, take off the old one, put the new one on, and that's all.
I recommend to anyone that plans on doing their own repair/maintenance work on buying a Haynes Service manual. Should be able to get one at your nearest auto parts store. This way you don't have to run to the computer in the middle of whatever your doing to figure out something. They're very useful [img]graemlins/thumbsup.gif[/img] .
And there is not very much space to work with down under where the fuel filter is at so take your time.
oh ya, i actually just looked at my old one and realized it had no o-ring. and it came from the factory. i'm guessing it isn't really that big of a deal if you don't have one. it's for sealing purposes anyway, so if your car eventually leaks fuel underneath where the filter is, i would go buy an o-ring and put it on; in the meantime, i wouldn't worry about it. i didn't have problems with mine for 65k miles and it had no o-ring. i especially wouldn't worry about it if you plan on changing your fuel filter every 10k or so.
hahaha, it really depends on how often you want to take a fuel bath!
I changed mine at 42k and don't plan on changing it again any time soon.
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre http://seppo.hopto.org/
Just changed mine at slightly over 75k. The old one (original) wasn't all that dirty, and there wasn't much of a performance change, but it was still worth it (especially after that many miles). Not too much fun after gas soaked into my skin and began to burn in my pores, but overall, it was a fairly quick install and good maintenance.
Chris Johnson<br />\'06 Cobalt SS/SC<br />\'95 Camaro - SOLD
