what is this? (picture) - FirebirdV6.com/CamaroV6.com Message Board
  • what is this? (picture)
    http://www.geocities.com/mike_1305/untitled.JPG
    i know it's a vaccum hose, but i dont know what for. in that picture, it is undamaged, but since then my idler pulley was fried and my serpentine belt came off. whatever happened along with it made this hose come off, and the plastic part that is circled was cracked on the side, thus stopping the whole vaccum thing. any help is appriciated.
    [ January 05, 2005, 07:15 PM: Message edited by: mike h ]
    fixed it. i guess it makes a difference if "JPG is capitalized or not.
      EVAP. ;)
      [ January 05, 2005, 07:29 PM: Message edited by: 98Camaro3.8 ]
      Matt
      1998 Mystic Teal Camaro M5
        the tube looks like it's part of the emissions system. THe vapors form the evap canister & all that. letting the fumes get sucked into the intake instead of venting to teh atmosphere. The round thing, is the IAC valve according to the holy book haynes.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          is it important, should i have it fixed or does it not matter.
            where is this canister located? i've read about it in my haynes but it doesnt specify where it is? also where is this EVAP line on the 3.4?
            <b>1995 Bright Red 3.4L</b> <br /><a href=\"http://www.cardomain.com/id/94camaroguy\" target=\"_blank\">Carmen\'s Page</a>
              the evap line on a 3.4 is one of the three fuel lines...it runs to the bracket on the side of the manifold.
              Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
                That is the same vacuum line that cracked on my engine and it threw a p0441/p1441 SES code. The line is plastic and cracks with ease making a vacuum leak in the evap system. I replaced it with a rubber hose, and haven't had any problems since.
                  how important is this piece to the car? what does it do?
                  "" letting the fumes get sucked into the intake instead of venting to teh atmosphere. The round thing, is the IAC valve according to the holy book haynes.""
                  what does that mean? why would you want "fumes" to go into the intake? is it a smog thing?
                    It recycles the fumes that didn't get burned up, ultimately keeping the fumes out of the atmosphere and giving you slightly better gas mileage...I think [img]tongue.gif[/img]
                      correct, Plus also on all OBDII systmes, 96 and newer cars, the evap system is part of the OBD system and is vital for the car to pass inspecion. If there is a leak in the system some where the check engine light will come on. My advice is to get it fixed asap. The longer you let it go the bigger the problem will become later on.
