vacume leak? - FirebirdV6.com/CamaroV6.com Message Board
vacume leak?
  • vacume leak?
    car was running fine... so what di I do? f it up! :mad: i went to check the pcv valve, and it was real hard to pull out, so after about 5min. i got it out, dropped the spring back in and the new valve. later that night, i started it back up. and it is the worse idle ever. the whloe car sways from side to side. kind of embarrasing, but i just tell everyone it a mean cam [img]smile.gif[/img] ... sound just like one...so SOMEBODY HELP! what do i do
    Pat Spalding<br />1998 Firebird 3.8L A4<br />BMR control arms<br />NX wet kit<br />80 series flowmaster
    You might have cracked the vacuum line, or knocked one the plug wires loose.
    What year is the vehicle?
    If it is pre-96, you might not get a SES light from the wire being loose, and the older the car, the more likely it is that you could have cracked the vacuum line that goes to the PCV valve.
    ...it\'s lonely out in space...
      ttt
