I might try to give it a little shot of WD40 or something like that to see if it helps. Anyone else had this problem?
Alternator making whine noise
1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.Tags: None
It sounds like the bearings are shot. You'll probably have to replace the alternator. I'm on my 5th one!95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
There are places that will do repairs for such thing at a cheap price. The bearings should not be hard to replace at all. You might want to see if you can get them from a repair shop and do it your self. Or just deal with the whine.White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
If the alternator is making a whining noise, I would check the output to make sure that you are still charging the battery.
What can happen is that if a set of the diodes goes out, the 3 phase AC machine becomes an unbalanced 2 phase AC machine, and the unbalanced currents cause the armature and rotor to vibrate at a frequency dependent on the engine speed. This can sound like like a bearing whinning.
You can check to see if it is charging by turning on all electrical loads and measuring the voltage at the battery. If it won't stay at or above 13 volts while at an idle, it may be time to consider rebuilding or replacing the alternator....it\'s lonely out in space...
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...22 hours ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
