I would suspect wire, plug, coil, ICM in that order.
The condition of the spark plugs can help diagnose problems. For example, if you get bad stumble at idle, shut the engine off and check all plugs. Find 5 that are tan/off-white and one that is black/wet and you found your problem cylinder.
