How do remove the water pump pulley on a 3.4? - FirebirdV6.com/CamaroV6.com Message Board
  • How do remove the water pump pulley on a 3.4?
    please tell me ho to do this, i am stuck and this is holding my up.
    its just 4 bolts that hold the pully itsself to the pump. Might have to put it in a bench vice so it won't move on you. But when I did it I had air tools to help me so it was easy to put the pully on and off.
      It's just four bolts holding it on. If the pump is on the car, keep the serpentine belt on while unbolting the pulley... it makes it much much easier if you don't have air tools.
      \'97 Camaro 3.8L
        god bless the man who invented air tools [img]smile.gif[/img]
          u can have a friend hold the pulley while you unbolt them, the bolts dont have too much torque on them. or find a screwdriver and jam it in, shoud work like a charm, i personally only need to use air tools when i took off my crankshaft pulley
          I will take on all comers...or come on all takers!!! Whichever you prefer.
            wtf are air tools? pictures ?
              i see
              air tools attatch to an air compressor, they have air ratchets,air hammers, air guns, pretty much regular tools that use compressed air instead of man power
                An electric or an air impact gun works wonders in this situation.q
                  i did the screwdriver jamming thing when i took the water pump off of a 3.4 in my class. worked great [img]graemlins/banana.gif[/img]
                  [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                  2000 3.8 A4 Pewter Camaro
                    A screwdriver should work, but a crowbar should work better, even a light tap w/ a hammer. :D
                    ---Niño---<br /><i>95\' silver 5 spd</i>
                      </font><blockquote>quote:</font><hr />Originally posted by 00firebird:
                      [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] </font>[/QUOTE]i meant, what are air tools. anyone have pictures.
                      two seperate sentences.. [img]graemlins/rofl.gif[/img]
                        http://www.sears.com/sr/javasr/search.do?BV_SessionID=@@@@1010234668.1105300806@@ @@&BV_EngineID=ccdiadddieejhmhcehgcemgdffmdflg.0&v ertical=TOOL&cat=Compressors+%26+Air+Tools&subcat =Automotive+Air+Tools&displayTarget=Subcategory
                          I took the belt off, and held it with a pipe wrench
                          Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
