My 1995, 3.4L Camaro is only getting like 150-175 miles per tank of gas. My foot gets alittle heavy once in a while but not too often.
What can i do to my car to hopefully improve milage somewhat?
I've changed my plugs/wires, i have the SLP CAI, and a new carsound cat to my dynomax super turbo muffler.
Any suggestions on what can help??
1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
Have you had your fuel regulator checked or the ERG system and definantely the oxygen sensors. The oxygen sensors, I almost positive that you have two, need to be replaced every so often which if they are bad then it causes them to give the cars computer false readings and cause false air/fuel ratio. Let me know if you need anymore help just email me at skullcamaro@aol.com(better to do the first option) or post here to contact me.
1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
definatley check O2 sensors, and also I know it sounds stupid but your tire pressure will reduce your gas mileage as well...make sure everything's oiled up and check your air filter, if its too dirty you'll lose power and get poor gas mileage....maybee just do an induction service, clean the throttle body and such....
errr, this doesnt sound too good for me. i forgot to mention that i had my fuel filter changed alittle while ago, and i changed my oxygen sensors too. I just put new tires on so they all have the right pressure in them.
Wheres the fuel regulator and the EGR and how do i check them??
for real
when i drive like i normaly do i get about 200 mpt
when i drive like a normal person [img]graemlins/rofl.gif[/img] I get about 260
Iv changed plugs and wires/K&N filter exhaust tires ok, just put in new o2 sensors about 2 months ago... I think im going to take a look at the fuel filter..... how would i go about doing that?
<blockquote>quote:</font><hr>Originally posted by Camaro_SLP:
Wow..if you have a 2000, I wonder how well it would affect my 94 by changing that filter..<hr></blockquote>
Have you ever changed it? It's suppose to be done at 30k miles. I changed mine at like 115k, I had never changed it before, but I'm sure it was probably changed at 30k or so miles by the dealer :eek: ...
Alls I have to say is BG44K, that stuff really works, I am back to my original gas milage! The stuff is about 17-20 dollars a can, and I picked it up at my GM dealership. But it does work, car runs way better, and better mpg to top.
<blockquote>quote:</font><hr>Originally posted by twofaced: Alls I have to say is BG44K, that stuff really works, I am back to my original gas milage! The stuff is about 17-20 dollars a can, and I picked it up at my GM dealership. But it does work, car runs way better, and better mpg to top.<hr></blockquote>
What is it?
Do you think i should try a can of seafoam in my vaccume line and some in my gastank?
