Can anyone tell me if there is any way to remove the pulley in front of the power steering resevoir (top right pulley on a 3.4). i have all screws out except the 2 behind the pulley, and want to know if there is an easier way. thanks eric
Removing power steering pulley and assembly
There is a special tool made for that. It's called the PS Pump Pulley remover and can be rented from Autozone for like $15 or so. You will need it to install the pulley back onto the shaft. When you are done with the tool, you can return it for a full refund.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
for the pulley its like viper said.
for the power steering assembly, theres one screw very visable by the crankshaft pulley.
another-right above it in a hidden area, in the "pocket" of the power steering assembly <ill try to get a pic>
another to the right of the coil packs, and one more behind the 1-4 coil pack, so dissammbly of that s required too.
then you have 2 15mm nuts in the back, those are the real pain.
then just pull the pump out and down. thats all to it.
and just in case u didnt know, you dont have to take off the pulley to take off the assemblyI will take on all comers...or come on all takers!!! Whichever you prefer.
