Jet Chip break in time - FirebirdV6.com/CamaroV6.com Message Board
  • Jet Chip break in time
    How long does it take for this thing to "break in"? I doubt I installed it wrong since the car is running fine. I have put only 15 miles on the car since I installed the chip so I'm not expecting it to work instantaneously. I was just curious because I was expecting it to atleast run the fan quicker because I have the 160 stat in there. Any feedback would be greatly appeciated. Thanks. [img]smile.gif[/img]
    <b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
    When I put mine it I think it took a good 30-40 miles for the computer to figure out what's going on.
      Reset your computer (turn car to ON position, not engine running, just on, remove pcm bat & ign fuses)
      Just to make sure its reset
      And give it a good 1-2 weeks to fully break in (though I did feel a difference right away off the line in mine)
      2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
        Thanks for the responces. I hope it does kick into gear soon. I've heard that most people are happy with them, I hope I'm one of those people. All I mainly want is for the chip to run my fans and if there is a performance gain then HELL YES! :D Okay, whatever that was kinda stupid. [img]graemlins/dunce.gif[/img]
          Not to sound stupid, but does the chip do anything with the fans? Seems like that would have been something that they would've mentioned.
          <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
            reset computer then drive around the block a few times slowly before you take it out into town
            \'02 firebird 5spd manual (pewter)<br />mods: whisper lid, spintech muffer with 3\" piping, strut tower brace, \"free ram air\", k&n filter, SLP CAI - next mods: jetchip stage II, lowering springs
              The jet chip doesn't do anything to the fans or when they will come on, that's what the manual fan switch is for which I and others will highly recomend, specially with a Jet Chip. If your engine gets hot then with the Jet Chip advancing your timming, knock retard will deadvance it beyond what it would be if you didn't even have the chip.
              I think maybe the Hypertech chip will change the fans but who has patience to wait for that to come out.
              1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
                I remmember reading a post not to long ago where BATMAN is explaining how the whole s/c project came up about on the fbody.com board and he talked about how the jet chip kept his engine cool?? I have gotten some performance from the chip but my car runs just as hot. I guess I might see more of a performance gain when it gets cooler outside or if I decided to install a fan swith. This is curious because the claim that the stae 2 chip should be used with a lower temp stat?? WTF?? If it wont cool the engine, why would you need the stat for? I thought if told the PCM that the 160 stat was there to set off the fans quicker? If this is not the case then they pulled a fast one on a lot of us. None the less, a fan switch should fix this, right fellas? [img]graemlins/dunce.gif[/img]
