car wont start - FirebirdV6.com/CamaroV6.com Message Board
car wont start
  • #16
    first of all im 16 and turned the same thing you did with basically everything stock expet for a whisper lid and k n and i live in texas so dont tell me about heat and humidity come here on a saturday night in july and ill show you
    2nd your there one who wanted to point out my grammar so buddy dont dish it out if you cant take and last but not least
    IM 16 and i probaly know more about cars than you well clearly when you run 15.60 i must know way more than you and buddy i took my engine out rebuilt it and put it back in come talk to me after you do that oh wait you cant only thing you can do is correct grammar
    1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
    • #17
      the only reason you were able to rebuild your engine was because everyone on the board had to explain it in all your posts. [img]graemlins/twak.gif[/img]
      Past Ride
      1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
      (If you dont know me, you haven't had a V6 long enough)
      Current Ride
      2006 Mitsubishi Evolution GSR
      www.myspace.com/shane1015
      • #18
        i find it funny that this kid is insulting the ones he NEEDS to help him. if i was getting help from a member on here, i would show the upmost respect and graditude.
        2000 3.8 A4 Pewter Camaro
        • #19
          I think it's funny how they both burn eachother, and then have a normal Q&A on the next line down.
          -Your Momma's a Ho
          -How do I fix my problem?
          • #20
            well **** i notice anytime someone insults me and i say soemthing back all you followers come and have to say something shane what did you help me on nothing i can rember... but if you say so and blldogg i didnt insult him first i was just being nice and ask a ? and than he wrote about my grammar how many of yall spell check everything you write i hope not man this isnt a freaking job its a post asking for some help so why not just either answer the ? or dont write at all like most of the other people on these board do
            [ September 17, 2004, 01:30 PM: Message edited by: therock ]
            • #21
              therock,
              How did you check the coils? Did you check the secondaries [between 5,000-6,500 ohms by touching the top terminals of each coil] or the primaries [taking off the coil pack from the car and checking the bottom terminals; should be between 0.3-0.6 ohms if I remember right]. I had to shove a paper clip in the primary terminals to get a reading with the test probes because it's a really narrow opening.
              My car has had 2 of the original coil packs go bad. The meter showed something wrong with the primaries and not the secondaries in my 2 cases.
              Also, when both coil packs went bad, it started as a random misfire and got to be really bad in the course of 2-5 days. It degenerated quickly. I don't know if that's what usually happens.
              ***One final bit of advice if the misfire happens at idle and it's coil-related: remove the plug wires from the coil, one at a time, and keep restarting the car after removing each one. Each time you do this, the car should run even WORSE until you find the coil that is causing the problem. In essence, if the car's usually hitting on 5 cylinders because of the misfire, it will run on 4 of them until you find the bad coil pack.
              Sorry I can't answer your no-start question.
              \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
              • #22
                yeah i took the coils off the icm and check them how you said on the primarys and on the bottom terminals and they were good if i cant get here runing again ill check for the bad coil like you said thanks man
                • #23
                  well changed cam sensor and it didnt help at all so?????
                  • #24
                    well had a mechanic come out and do tests on tthe car he sid its not getting any fire so he checked all fuses and pcm and wires and said it gets power all the way tell the icm which i just replaced and had it checked last week and orileys said it was good so why is the power not going out if the part is good
                    • #25
                      • #26
                        I would help.. but I am 100% confused as to the actual problem no matter how many times I re read the post
                        1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
                        • #27
                          lol sorry but basically the engine isnt getting fire but the only thing that they can find wrongis the the icm is getting fire in but not giving it out buti had the icm tested by orileys and they said its fine
                          • #28
                            He couldn't fix it for you?
                            Take it to someone else.
                            -1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
                            • #29
                              he said he never seen anything like it he put it on a snap on scanner and said that no codes show up and everything was reading fine but he put this light on the injector and said it still had no fire so i dont think that he is doing something wrong i trust him his a friend but io have a ? if you unplug your pcm for like 3 months do you have to get it flashed
                              • #30
                                coils
