I grew some food for thought as I drove home from work tonite.
Every day, I cruise home on the same road at 48mph. I keep my M5 in 4th gear and it stays at 2000rpm. Manifold vacuum is 13-15 inches, depending on the weather.
If I shift into 5th gear, I can lower the rpm by about 400, but I have to open the throttle much more to maintain speed. Thus, the manifold vacuum goes down to about 6-8 inches.
WHich cruise setting is more efficient? low rpm and low man. vac. or moderate rpm and high man. vac? In fligt training, we have been taught that lower manifold vacuum will be substantially less efficient. But most any car driver will tell you that low rpm is the most efficient.
I wonder if they would be equal. Does anyone know the equation for finding out required cfm? I know you need to plug in displacement and rpm.
I think we would also need to look at a fuel map graph to solve this dilema.
Now that I am done thinking out loud, what do you all think?
