heya, i cant adjust the position of the airflow from my vents anymore! it is stuck just blowing at the feet, whenever i turn the knob to blow through the defroster or vents it just blows to the floor and doesnet make that PISHHHHH noise anymore...
any ideas??
Reg
Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
you can pull off the actual knobs by just simply pulling them out towards you. You might have rounded the insides off. Check to make sure that didn't happen. If you did, i'm sure that you can possibly get new knobs from the dealer or something (or a online fbody salvage site)
Ok, this happened to me too. My problem was I had a vacuum leak under the hood and that directs whether you want air conditioning at your feet, head level, etc.
This is where my problem was (I don't know if it's the same on the 3.4s):
On the passenger side, under the hood, near the hood strut, there is a small black cylinder check valve. Connecting to the cylinder is 3 vaccuum lines, one at the bottom, one on the side, and one at the top. If you have this part and there is a crack in it or one of the lines blew off you've found your problem.
Went to the dealer, bought the $7 part, put it in and I have ice cold AC in the top vents, and I haven't felt holyness like that since I purchased the car over a year ago.
Hope this helps,
Sam
Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
