i put a resistor in my wiring to bypass the broken ignition lock cylinder (see other post). well, my teacher told me that hes not sure about the pass 3 system will lock everything up for good cause it can since a resistor. it has something to do with leaving the key in for days and it will lock things up. anyone know if this is a problem i might face?
Pass 2 lock system
Tags: None
This is the PassKey 2 system, not 3. Putting the resistor in is a very common thing, and I've never heard of anyone having problems with it. If the system senses a fault then it will default to "Fail Enable" mode, which means it will work as if it wasn't even there.Matt
1998 Mystic Teal Camaro M5
ok good, he wasnt too sure if it was a passkey 2 problem. but he said the new passkey 3 system will sense it and lock your car up for good. can someone say a new comp :D lol
he thinks that if you remove the resistor, that the lock out will open :shrug: not a problem for me [img]smile.gif[/img]
I just did some reading in the GM Service Manual. The newer cars have a system known as Passlock, which is different than PASS-Key. Passlock doesn't use a resistor in the key, and it works completely different. Looks like it would be a little harder to bypass.Matt
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
