I need some help because my cigarette lighter power is out. I try using my cell phone charger and it wont turn on. I checked my fuse and its fine...any ideas?
Lighter outlet not working
sure you checked the correct fuse? the cig lighter has its own special fuse i believe. its a real low amp fuse and blows easily. ive done it several times.
uh.. if your going to clean the fuse block with a METAL wirebrush.. unplug the battery [img]smile.gif[/img]
but, it should be the fuse, make sure your checking the correct one.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Originally posted by My3birds:
unplug the fuse, then stick a wire brush or sandpaper in the outlet and polish it. Alot of corrosion gets on those over the years---Niño---<br /><i>95\' silver 5 spd</i>
I think on our cars, in the fuse box, its the "courtesy" fuse. Check that one, only other thing besides that is take off the plastic peice housing the ciggarette lighter, and check the wires/connections connectec to the back of the ciggarette lighter. Sometimes those mess up. Good luck. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
The attachment storage directory does not exist or is not writable.4 hours ago -
by 2.8 BirdSo there going to be anything new or update to the site since Bill is now the owner?
I know there's still alot of interest in the fbody V6....3 days ago -
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...2 weeks ago
