More low end torque - FirebirdV6.com/CamaroV6.com Message Board
More low end torque
  • More low end torque
    What can I do to get some more low end torque?
    I currently have 3.42 gears w/lsd, edelbrock exhaust, k&n filter, and lingenfelter cold air induction. I just had the 3.42 with lsd in hopes of being able to really put some low end into that car but it did not do it. I want something where when I step on it I will break the tires loose. Any suggestions? Cam maybe? Or something a little cheaper?
    Edelbrock Exhaust System<br />SLP Air Temp Module<br />K&N Filter<br />Lingenfelter Cold Air Induction<br />B&M Shift+<br />3.42 Motive Gears<br />Zexel-Torsen Limited Slip Diff.<br />Texas Speed Retuned PCM<br />180 Degree Thermostat
    well it would help to know the year of the car but headers will give you more lowend depending on the year. Could always get a blower or nitrous.
    1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
      intake, exhaust, and ignition.
      2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
        My car is a 1997, I do have the restrictive manifolds but if anything headers I think actually lower backpressure to the engine and you lose low end torque that way while gaining high end power
          In response to Pat, I have moded the intake, and moded the exhuast (excpt. cat converter, and headers) and I have not yet touched the ignition which I know MSD offers DIS 4, but I dont think that will give me the boost of power im looking for. More or less low-end torque.
            get an aluminum DS. what rims & tires do you have? do you have TCS? if yes, turn it off.
              Onyx, I have a TCS but I never have it on, I know for sure its off. You have any clue how much of a gain I would see with an alloy driveshaft?
                An Aluminum Driveshaft will give you a little bit, but don't expect much, maybe 5 ft-lbs.
                -Jason<br />Black 1993 Pontiac Firebird -Retired<br />Black 2002 Pontiac Trans Am -Sold-<br />Green 1996 Corvette Convertible -Sold-<p>In the market for \'67-\'73 Firebird!
                  When it comes to low end torq, there's no replacement for displacement. An aluminum driveshaft will help some with it but will also smooth out the ride. If you shoot nitrous from a stop you might get one good pull before your engine blows so i'm going to have to contest against that suggestion ;)
                  1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
                    stock stroke is 3.4 in., stock rod length is 5.750 in. have a custom stroker crank made w/ a 3.5 stroke & a 5.650 rod, or 3.6 in. stroke & a 5.550 rod. you may wanna look into buying L67 pistons because of the extra compresion you'll make. it'll cost a lot, but will give you more low end. you'll wanna get headers and 2.5 in. exhaust piping(stock is 2.25) just to keep the torque peak around the same rpm as before.
                      <blockquote>quote:</font><hr>Originally posted by smhcamaro:
                      Onyx, I have a TCS but I never have it on, I know for sure its off. You have any clue how much of a gain I would see with an alloy driveshaft?<hr></blockquote>
                      you still did not answer my question: what rims & tires do you have? i think the aluminum DS should be enough for what you want to accomplish. it did for me. but it may still depend on how wide and sticky your tires are.
                      i think you know this but i'll just say it anyway: TCS always comes on everytime you start the car.
                        get the 1le driveshaft, like they already said, and maybe a torque convertor.... if you don't do lots of highway driving, you oculd look into 3.73's.
                        Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
                          14" rims should light up real good. will also let you scoot qiucker, but make you red line faster & hurt top speed.
                          edit: try a line lock.
                          [ May 30, 2002: Message edited by: 2.8 slow to go ]</p>
                          2013 Ram 1500 Big Horn
                          94 comero 3.4
                            Onyx, I have 245/50-16 Bridgestone Potenzas, I think I may look into a torque converter once I know a little more about them, I just had the 3.42 w/LSD put in the other day, and I probably will go with the alloy driveshaft. Thanks everyone for the help it is really appreciated
                              2 days ago
                            • Doodler
                              97 Camaro base with expensive sounding noises
                              by Doodler
                              Still trying to find oil leak
