If you read from my recent thread, it turns out that my battery is going bad. Big deal, easy to replace. Well, the positive battery terminal is incredibly corroded, and in trying to get the bolt off we've stripped the bolt! I tried WD-40 and then vice grips, but it still will not turn! Is there anything else I can do other than taking a hacksaw to that bolt??
Battery terminal is corroded like a mofo! CAN'T GET BOLT OFF!
Tom<br />Too many mods for this sig.<br /><a href=\"http://www.l337server.com/Tom/cars.html\" target=\"_blank\">My car\'s site</a><br /><br /><a href=\"http://www.FullThrottleV6.com\" target=\"_blank\">www.FullThrottleV6.com</a>Tags: None
yeah, i would go get some type of terminal repair kit and just replace it
Side post terminals are easy to replace, just cut it and carefully splice a new one on. They also sell anti corrosion spray to, you could spray it down for future protection.-Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
Originally posted by L32Projekt:
Umm, Coca-Cola? [img]smile.gif[/img]www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by BobsSilverSix:
Or you could use a pipe wrench. They work on anything, trust me I'm a plumber.---Niño---<br /><i>95\' silver 5 spd</i>
semen has always worked~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
