Hey guys I bought a 180 Thermo and I was reading the instructions on the back and it says you must drain the cooling system. Is this necessary? [img]graemlins/burnout.gif[/img]
Installing a 180 Thermo - - Must cooling system be drained?!?
<b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>Tags: None
Hell no.
Someone should post to whether or not there is a drain plug though. I dont know if there is or not.
On my old '00 Blazer there was no drain plug on the radiator and when I installed the 160 deg thrermo I just pulled off the hose to the t-stat and just let the minute amount of antifreeze hit a bucket I had under the truck.
So, if there is a drain plug, drain a very small amount. If not, or maybe even if there is one.. just pull the hose off - it's all good. Expect an extra 5 minutes to your work to clean up the floor.2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
Thanks Cale. There is a plug on the radiator though. I remember I drained my old antifreeze last time there were freeze warnings and I put in some new one. [img]graemlins/burnout.gif[/img]
[ March 08, 2002: Message edited by: marco ]</p><b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
when i installed my 160, very little fluid came out, all i did was add some more. simple as that.1998 Red Firebird A4 3.8L (3.08)<br />Dynomax bullet then dumped, Carsound cat, NGKTR55 plugs, Taylor Pro 8mm, Hypertech 160*, Whisper Lid, k&n,!FRA, Lifted Airbox<br />(2) Audiobahn 10\" subs<br /> Sony Xplod MP3 Head unit/interchangeable Color Display
