Checked out my reservoir yesterday and the coolant is looking like scum, all sorts of oil in it. Any ideas what it is?
Oil in coolant
blown head gasket, causing mixing of oil and fluid. This will be a costly repair if you can't do yourself.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
Yup, chances are you've got a blown head gasket. Don't drive the car until you know for sure what is wrong with it. Pull the car in the garage and drain your oil. If it looks like Chocolate milk, its pretty much for sure.
You have either a lot of work or a pricey repair coming up.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
another thing to think about is... is this just in the coolant? if so do you run the orange coolant? if so then change the coolant it just gets nasty. but also check the other things like the oil and see if it is nasty also before you trust to bad coolant.Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
It's not coolant in the oil, it's oil in the coolant. So i don't think it's a blown head gasket. My mechanic thinks it might be the timing cover(i think this is what he said), says it the gasket needs to be replaced...EZD<br />1996 Camaro <br />K&N FIPK<br />Borla 3\" Exhaust<br />Dynomax 3\" Cat<br />Panasonic Ghost CD Player
i dont think so. if the oil is mixing with the coolant anywhere, there will be coolant in the oil [img]tongue.gif[/img] it might just be some old nasty coolant. just to make sure, did you check you oil?
The oil cannot be going into the coolant without the coolant going into the oil. If the two are meeting, they will exchange both directions.
If you think the oil is clean then I guess flush your coolant and see if the problem comes back.1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
How many miles does you engine have?
They like to let go at about the 120,000 mile mark in most cars.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
