My car never leaked but maybe 3 drops over night since iv had it.... not enough to do anything.. Everytime i change my oil, i can never remember if it takes 4 or 5 quarts and i dont remember what i have bought b4....I got 5 quarts this time and now i notice a leak in it after sitting at night... a puddle on the ground about the side of 2 quarters ( yes $$ ) on the ground.....
Did i fill it up too much and that ismaking it leak out?
I havnt had enogh time to look for it and find out where its coming from ...
That's exactly what it says. Always change the filter when changing oil though. And 4 quarts is enough, even with a new filter. I always use 4 quarts and the level is right in the middle of the hatch marks.
I doubt that it is leaking because it was overfilled. Most likely valve cover gasket is leaking or worst case, a main seal.
[ May 05, 2003: Message edited by: need4speed ]</p>
Where the hell are some of you getting 5 quarts from as the factory #?
The OFFICIAL GM MANUAL says 4.5 quarts with a filter change. That is when using the factory reccommended oil filter size (AC Delco PN PF47)
I, however, use a bigger oil filter (Delco PN PF52). This longer filter fits in just fine (3.8s can use this too), and with a bigger filter, it allows us to use a full 5 quarts of oil.
