Hypertech Power Programmer - FirebirdV6.com/CamaroV6.com Message Board
  • Hypertech Power Programmer
    Hypertech's Power Programmer allows you to get rid of the rev limiter. My question is this: Wouldn't that do harm to the engine to be running it at 6500 rpms or higher? (above redline).. Just curious. Hypertech also says that "The stock computer is programmed to shut down the engine when it reaches the redline." This has never happened to me
    Another thing.. For the 1997 3.8 L Camaro (and all other applicable models) What is the redline 5500 or 6000?
    [ May 29, 2002: Message edited by: fathazam ]</p>
    1997 Medium Quasar Blue A4 Hardtop<br />Stero<br />Alpine Stereo CDM-7857,Kenwood Amplifier KAC-848,Two 12 Inch Pyle New Wave Subs<br />Appearance<br />Headlight, TailLight, and Turn Signal Blackouts, Limo Tint on Hatch, 35% Tint on Sides, Orange Painted Calipers and Drums, Orange Engraved Camaro, Orange Painted Hood Scoops, Orange Camaro Windshield Decal<br />Performance <br />160* thermostat, Custom T/A dual exhaust, K&N Filter, NGK Spark Plugs, All Synthetic Fluids (Maybe not a mod but costs some damn $$$), 80 Series Flowmaster with Custom Dual Exhaust, (In The Making) 3.42 Gears, Zexel Torsen Limited Slip Differential, Goodyear Eagle 1 \"Z\" Rated Tires<br /><a href=\"http://darius.100megsfree5.com/home.html\" target=\"_blank\">http://darius.100megsfree5.com/home.html</a><p>So Its not the fastest car ever made... The girls love it anyways.
    The HPP3 allows you to adjust the rev limiter in 100 RPM increments up to a limit of 6500 or 6600 RPM. This can be useful since using the HPP3 changes the engine's programing and to maximize the new programing you can squeeze a few extra RPM from the engine. It is not unusual for the factory to rate engines somewhat on the conservative side so a few extra revs are not necessairly damaging. However, I don't think it is a good idea to run an engine at the top of its RPM range all the time.
    2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
      I here that we should be able to go up to 6200rpm safely with the stock springs. I wouldn't go over 6100 myself.
      <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
        <blockquote>quote:</font><hr> The HPP3 allows you to adjust the rev limiter in 100 RPM increments up to a limit of 6500 or 6600 RPM. This can be useful since using the HPP3 changes the engine's programing and to maximize the new programing you can squeeze a few extra RPM from the engine. It is not unusual for the factory to rate engines somewhat on the conservative side so a few extra revs are not necessairly damaging. However, I don't think it is a good idea to run an engine at the top of its RPM range all the time. <hr></blockquote>
        Correct me if I am wrong, but with a 3.8l out of the car, peak power is at 5200, with it in attached to the tranny, etc... i'm guessing it would be about 4800...
        What is the benefit of getting the engine above 6000? Unless you have really nicely ported heads, I don't think that a 3.8l could breath enough to produce good power at those rpms...
        Even with the super six power pack, max power is at 5700...
          And you know this because you have the powerpack and have tested it? :rolleyes:
            5700 is when the a4 changes gears when you floor it [img]tongue.gif[/img]
              <blockquote>quote:</font><hr> And you know this because you have the powerpack and have tested it? <hr></blockquote>
              No, I just took the time to read the site [img]tongue.gif[/img]
              http://www.supersixmotorsports.com/PDF's/All%20Dyno%20Data.pdf
              [ May 31, 2002: Message edited by: Jeff Pristelski ]
              [ May 31, 2002: Message edited by: Jeff Pristelski ]</p>
                Im pretty sure that with a bigger cam it takes your peak power up in the rpms so if you dont go above 5200 after you get a bigger cam then you wont reach your peak power, i think the bigger the cam the higher it raises your peak power in the rpms
                  doesn't matter what tranny you have, peak power is STILL at 5200 rpm. and that fluctuates with mods...IE, exhaust will move the power band up in the RPM range, but i'm not sure by how much. and sometimes it's beneficial to run it past power peak, so you can get as close to 4000 rpm for the next shift...IE the 2-3 shift...if i shift at 5200, that lands me back at like 3500 or 3600 for third gear...not good at all. see what i mean?
                  2011 Camaro LS 6M, in black.
