tach acting up - FirebirdV6.com/CamaroV6.com Message Board
tach acting up
  • tach acting up
    everything runs fine its just that the tach needle jumps all around when driving. any ideas?
    jon
    {1995 3.8 A4}{Flowmaster Exhaust}{SLP CAI & Fan Switch}{4 Wheel Disc Brakes}(3.42 LSD}<br /><br />{2004 Dodge Dakota SXT 3.7L SOHC V6}{Cold Air Intake}{Dynomax Ultraflo 2.5\" Catback}<br /><br /> <a href=\"http://members.cardomain.com/95blackbird3800\" target=\"_blank\">http://members.cardomain.com/95blackbird3800</a>
    Hmm, check the connections around the coil packs. Other than that I cant think of anything.
      hey mine does the too, the tach will stop working and after i red line it it will work for a while again........
      www.turbov6camaro.com
      1997 3800 Series II Camaro
        my engine sometimes goes into high revs sometimes when i am driving. I noticed mainly when i am in relatively high gear for my speed. when i hit the has it kinda revs up for a second or two (or three) and then stabilize itself. Any Ideas. Thanx
        Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
          Mine does the same thing, but mine will from redlining to zeroing out when I'm driving at a constant RPM. Mine actually seems to get better by wiggling the white tach wire where it goes into the PCM. I'm wondering if something got on that connector? Where do the tach wires go next after they come out of the PCM?
            i was watching mine with a scan tool the PCM is read ing the cooerct rpms, the tach is not getting it, it off buy like 500 rpm
              TTT
