-20* Spark Advance. - FirebirdV6.com/CamaroV6.com Message Board
-20* Spark Advance.
  • -20* Spark Advance.
    Nikon and I were out crusin sunday night....we hooked up his laptop w/ the OBDII software to my car...
    it said my spark advance was a NEGATIVE 20 DEGREES.
    -20*
    we hooked it up to his and his was 12* (12 degrees).
    Could this mean bad plugs???? LOL (most likely right?)
    correct that 12 to a 24 ;) even if its not the plugs you got alot of miles, well, kinda you need new plugs anyways....maybee new wires also?..
    05' CTS-V
    00' Camaro - SOLD :(
      u sure you programmed the proper year and info into the scan tool? i know if you get a year off sometimes you get funky readings on some sensors...
      ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
