Whats up all. It says to put the sea foam into a vacuum like that will input all cylinders. where would it be, i looked under my hood and im clueless. Any help would be greatly appreciated....
sea foam help
This topic is closed.
sea foam help
Pain heals, chicks dig scars, and glory is forever.<br /><br />------------------------------<br />1997 Red Firebird with T Tops<br />Custom 3\" cold air intake <br />K and N filter<br />!maf<br />flowmaster 80 series catback<br />Accel 8.8 300+ spiral ferro wires<br />Bosch 2X platinum +4 \'sTags: None
Pull the line off the brake booster and use that. It's the black thing before the Master Cylinder. Do a search in Intake/Exhaust and you'll find pics of it, along with some other info.Matt
1998 Mystic Teal Camaro M5
on the passenger side of the intake there was an L shaped vacuum boot. i took off the other end of that and used that. I poured in half the bottle then poured in enough to choke the engine out. let it sit for like 15 minutes. Turned on the car and not alot of smoke came out. I mean there was some. lasted like 10 minutes. But not massive amounts.Pain heals, chicks dig scars, and glory is forever.<br /><br />------------------------------<br />1997 Red Firebird with T Tops<br />Custom 3\" cold air intake <br />K and N filter<br />!maf<br />flowmaster 80 series catback<br />Accel 8.8 300+ spiral ferro wires<br />Bosch 2X platinum +4 \'s
<blockquote>quote:</font><hr> Do a search in Intake/Exhaust and you'll find pics of it, along with some other info.[/QB]<hr></blockquote>
THANK you!!
these sea foam posts are old and repetetive. I know that sea foam is seemingly the greatest thing since sliced bread, AND THEREFORE there are threads aplenty on the subject!2011 Camaro LS 6M, in black.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...3 weeks ago
