Anyone with the W-type wings west kit - FirebirdV6.com/CamaroV6.com Message Board
  • Anyone with the W-type wings west kit
    How hot does your car run? What have you done to keep the temperature down? I'm still having problems with mine hitting 210 after driving for a while. I'm considering selling my gfx and lowering it instead so my car wont run hot and accelerate so slow because of it.
    <a href=\"http://www.cardomain.com/id/sean37\" target=\"_blank\">Black \'97 Camaro</a> w/ CAI, catback
    did you remove your stock plastic flap/ airdam that is in front underneath and put a bigger wings west one on? I heard this really helps if you d]do, i think they are like 60.00
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
      Yes, I have the Wings West air deflector, but it was way too low. I would scrape it constantly and my car is not even lowered. Even when driving down the street at 45 if there was a small bump in the road it would scrape. So I had to cut a couple inches off it. But it's not getting enough air. So I think I'm either going to get a front spoiler from a RS kit or remove the whole thing and sell it.
        2 days ago
      • Doodler
        97 Camaro base with expensive sounding noises
        by Doodler
        Still trying to find oil leak
