I would appreciate it alot if someone will please pop their hood and put your hand on the power steering pulley and push in and pull out and let me know if it goes in and out like an 1/8" or so. mine does and i had some people say they are supposed to do that and the other half says no. thanks guys
will anyone please do me a huge favor? less than 5 minutes of your time
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
mine is a 3.8, maybe all yours doesnt move because of the serpentine belt i dont have my belt on and the power steering pulley moves in and out like 1/8" it also does this on my truck and my other car, i asked the guy up the street who builds race cars and he said its normal to have some movement and there isnt anything wrong. Oh well i guess ill find out soon enough when i actuallu run the car, thanks everyone for all your help i appreciate itLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
