Well, last night my car started running like crap. It idles fine, and will accelerate fine if I take it nice and easy. But if I get over maybe 50% throttle, it bogs BAD, almost like a misfire feels. I already replaced the fuel filter today. Any other ideas? It did it very abruptly last night after driving slo down a dirt road, check throttle body, no dirt or anything in there. Have been running injector cleaner very regularly last few months. Any help would be great, since I can;t take it for warranty until at least Monday. BTW, it's a '00 Camaro.
Already replaced, still have problems...
Try the Throttle Position Sensor... My IROC had that same problem when the TPS went out....99 3800 NBM Camaro - (Xcessive Xcelleration Racing Team)<br />Ram/Cold Air Induction (custom)<br />Modified 4l60e Valve Body<br />Z28 Catback<br />SS Hood <br />Modified 99 GM 3800II <br />JB Performance Engineering<br />jfbperformance@cox.net
My '97 had the same problem. It turned out to be:
The fuel filter was clogged, causing low fuel pressure.
The spark plugs and wires were worn. The bad wires were causing misfires in multiple cylinders.
I got everything fixed, and the car runs great. The car has 40,00 miles.
Hope this helps.1989 Trans Am, 305 TPI 5-speed, 4 wheel disc, 3.73\'s, T-Tops. \"The Toy.\" 1997 Camaro V-6 T-Tops \"The Daily Driver\"
I have the same problem with mine. It started doing it so I replaced the plugs and wires. It was still doing it so I took it to checked with the computer and showed it was something with wire/plug/coil3. So I thought wires and plugs are new so it must be the coil thats going bad so I went a ahead and replaced it. It was good for about 4 days or so and then came back. I though i should replace the fuel filter..it needed it anyway and I thought it could be part of the problem..but it was still doing it. Last night I changed the 2 other coils...still doing it. I checked it again and I am going to remove the wires and take them in to get new ones..they are under warranty. I think one of them touched the manifold and might have gotten messed up.<b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
Well turns out that even though I had just replaced the wires, one was bad, barely sending any spark to the plug. I assumes that when I checked them for good connections that my new wires would be good, but I guess not. So it was a warranty deal, and the receipt where it shows how much it would cost if not for warranty said like $50! For one bad wire and an hour of labor to find the problem. Damn I'm gonna miss my warranty!<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
