I have been reading here for a few weeks and have not found anything exactly like the problem I'm having.
I have a 94 3.4L camaro. The miss started after I put some fuel injection cleaner in it, but I'm not sure it has anything to do with it. When it first started I could shut the engine off for a few seconds and restart it and it would clear up Then it seemed to happen more offen and shutting the engine off and restarting would not always fix it. Now it is to the point that when I first start it {cold start} it runs fine but after I get down the road some it will start to miss. It also will do it any time I stomp it hard, and does not go away until shut it down and let it cool down some.
The miss reminds me of when you foul out a plug or two or burn a wire or two in half. Because of this I am thinking it might be a coil breaking down but am not sure. I'm taking it to run the codes tomarrow. The cat has been removed and the guy I bought the car off of did not put the o2 senser back on behind the cat but has run fine for 3 months until the last 2 weeks. It has duel exhaust and a cold air intake. Any thoughts?
