i am getting these:
P0300= gt2 cam
P0305= cyl 5 misfire black spark plug
P0174= low voltage bank 1 with new sensor
P0131= lean bank 1
P0171= lean bank 2
i had low voltage on bank 1-2 after the cat until i added a o2 sim
what do yall think. car is sputtering under load. i need lifters.
Will you be doing all the work yourself? First I would check and clean all the connectors from the battery to the sensors. I might even go as far as replacing the fuses even if they are not blown. Change out one fuse and check the connection with a volt meter before and after to see if it helps.
I would try cleaning the TB with a Carb cleaner first to fix the lean issue. If you still have a problem try adding a jet cleaner to your tank. I know people says that stuff does not work but but I think it could not hurt. I know my MPG went up when I ran a tank of it. It could be your fuel pump is crapping out or your jets need to be replaced, Its hard to say when there are so many options.
White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
Already e-mailed you some things Ceaton. You might also seafoam it for grins, clean out the top end some. Tak off the TB and clean around the blade, both sides, mine gets really nasty sometimes!
