Sea Foam - FirebirdV6.com/CamaroV6.com Message Board
Sea Foam
  • Sea Foam
    I ran tha sea foam through tha TB vac. hose but no ****e smoke is this a bad thing should I run it through again?
    You didn't have much carbon build-up. The more carbon, the more smoke.
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
      does anyone here have a picture of where to put the Sea foam in a 3.4 (94) camaro? im not so sure where i put it
      1994 3.4L Dark Green Camaro - Tan Cloth Interior<br />Mods - Flowmaster, High Flow Cat, K&N Filter, Window Tint, Premium Sound system (2 subs custom box, New 99 Z28 style Rims/Tires, New Clutch<br /> More to come!
        <blockquote>quote:</font><hr> Originally posted by genz11:
        <hr></blockquote>
        Read this
        Has a great pic Red2k1 found in there.
          genz11:
          I put mine inside a vacuum line between the upper intake valley. The intake sort of looks like a wishbone behind the throttle body. There are two black lines, which I think are metal, that join together right behind the upper intake. They are joined together by a rubber coupling. I pull them up, towards the hood, while the car is running. The RPMs jump up and you can hear the suction. I pour the seafoam as close to the hole as I can just to be safe but the suction at that point is so strong it can pull the fluid in easily. This might not be the best way but it's been working for me for several years now. It's also very easy to get to.
          Good luck! [img]graemlins/thumbsup.gif[/img]
          [ May 08, 2003: Message edited by: Harbin1 ]</p>
          95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
            ok my hose was rubber like and I started tha car and took unconnected tha hose and put it in tha bottle is this the right way? or do I pour it into where tha vac. hose hooks up to the TB?
              2 days ago
            • Doodler
              97 Camaro base with expensive sounding noises
              by Doodler
              Still trying to find oil leak
