HELP - FirebirdV6.com/CamaroV6.com Message Board
HELP
  • HELP
    I go to start my car today, and when i turn the key all i hear is the single click of the starter and nothing else. Does anyone know whats wrong with my car????
    1995 camaro 3.4
    1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
    yeah your battery is dead
    oh to make sure all questions are answered, if you charge your battery back up and it runs fine but won't start up after a short drive down the road, your alternator is probably bad. this means all power is coming from your battery and the alternator isn't doing is job of charging it back up. If the battery just seems to drain overnight and can't hold a charge, then it's just the battery.
    or maybe you just left your lights on?!
    [ June 01, 2002: Message edited by: C.Palmer ]
    [ June 01, 2002: Message edited by: C.Palmer ]</p>
    1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
      My batteries not dead, i just replaced it last week. My lights werent on either. I thinks it the alternator,,what do you think?
        ok my sources say alternator then. Your battery is not receiving a charge so it died. just charge it back up and replace the alternator. Your starter draws off your battery to turn the engine over so if your starter is clicking it's fine- leaving only 2 other problems.... a loose connection or dead battery. i didn't say replace the battery now did i?? hehe :D
          It was time for a new battery anyway.
          I got it towed the other day and got it fixed, somehow my starter was bad. I got a new one in and every things all better now. Thanks for the help
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
